Results 1 to 8 of 8
Thread: Should a pool heater sound loud?
    We recently had our pool installed and we put in a Hayward H250 LoNox heater. My neighbor had some AC work done yesterday and his HVAC guy said our heater sounded like it was getting too much gas and shouldn't sound that loud. My neighbor also said that one of the dials on the gas meter spins wildly while the heater is on. When the heater is on, it does make a loud rumbling, but is any of this abnormal? Can a heater get too much gas?
    16 X 32 Vinyl. Hayward aqua rite salt system, T -15 cell. Hayward H250 gas heater, Hayward 1HP superpump.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Should a pool heater sound loud?
    Yes, but there should be a feed adjustment on the heater - call either the installer or a gas guy to properly make that adjustment
    Luv& Luk
    -Ted
    Is the feed adjustment not something I can do? Thanks.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Read the manual for the heater, it should tell you what to adjust your flame to through the sight glass and how to do it.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    I read the manual and called the gas guy that did the install. He said he would check the feed for the amount of flow, which he said should be 3.5???
    How should the heater sound if the proper amount of gas is getting to it? Louder than the pump or quieter? Thanks.
    Mar 2007
    4,160
    With a nice quiet pump, the heater will be a little louder. "hawoomph" is the best I can describe the noise - if you have a flutter or squeak - the gas flow definitely needs to be adjusted!
    Luv& Luk
    -Ted
    No flutter or squeak. Just a constant rumbling sound while it is operating. They checked it today and said the water pressure was correct and they called the gas guy (they recommended him) and he said he checked the gas pressure and it was fine. They have told me to leave the heater off until they hear back from Hayward. They did say that because the heater is a 'pwer vented heater' that this will contribute to the noise. I know that the PB generally installs millivolt heaters, and I specifically requested an electronic one. If the gas guy typically installs only millivolt heaters, is there something he could have missed in the process? While an electronic heater is heating, what should it sound like?
    How big of heater?
