I like to think that the pump running and the daily filtering is also keeping the water from just being stagnent. Perhaps you're unaware of what clean, clear pool water can look like since this is your first pool?
Do you have people come swim?
No one here says you *must* run your pump for 8 hours a day...some run it for 2, some for 24. The skin cells and small debris need to be collected in the filter, and the use of an appropriate amount of chlorine to oxidize sweat, urine, etc is necessary. If you are trying to cut back on expenses perhaps running the pump at off-peak times would help you cut costs.
There is a difference between being frugal and being cheap. With a pool and its inherent responsibilities to maintain its sanitation you are risking the health of swimmers and the conditions of your water. The TFP methods help you care for your water in the safest, most frugal way.
