Results 1 to 9 of 9
Thread: Its me again, and i need help
    teppy's Avatar
    Nov 2007
    Louisiana
    120
    hi guys,
    i am a pain, i know. i am preparing for my SWG. yesterday, i checked all my numbers. my cya was between 50-60. i tested with the colorQ photometer and TF-100 to make sure. I added three cups of stablizer following the pool calculator. (target-70, now-60 16900 gallon plaster using TFP and bleach input selections).
    i know that CYA can take awhile to dissolve, but just now this am, it was all dissolved and I took a test sample. i used the colorQ test and it has not changed at all. I am still getting a 58 reading on cya. the only major difference would be the temp. yesterday afternoon the water was at 87 degrees. this morning and i wanted to have my CYA correct.
    17,000 gallon roman shaped gunite pool-AquaRite goldline SWG
    ktdave's Avatar
    Katy, TX
    888
    Re: Its me again, and i need help
    It still may take up to a week for the CYA to show up on a test even though it appears to have dissolved.
    11,000 gal. gunite w/midnight blue and white pearl PebbleTec
    Intelliflo 4x160 pump
    Intellichlor IC-20 SWG
    Pentair cartridge filter 420 sq. ft.
    Mastertemp 400K BTU heater
    Legend Platinum cleaner
    Pool School
    JasonLion's Pool Calculator
    TF Test Kits
    That amount of CYA will raise your CYA level by about 10 once it is fully dissolved. Since the CYA test in the TF100 is +-15, and the CYA test in the ColorQ is +-25 (when it is working) it will be very difficult to verify that small an increase by testing.
    I would add another 15 ppm of CYA, targeting a level of 80, and call it good.
    teppy's Avatar
    Nov 2007
    Louisiana
    120
    thanks jason. so, if i input target at 80 and right now at 58, that tells me to add 3lbs. 2 oz. i didn't add that much to begin with. is this right? i just want to double check so not to add too much.
    Butterfly's Avatar
    South Carolina
    10,045
    From CYA 58 to target of 80, 3lbs 2ozs is what I get from the Pool Calculator.
    You're done SLAMing when:
    There are various ways to estimate your current level. I would not start from the ColorQ reading. Instead, I would take your TF100 reading of between 50 and 60 from before you raised it by 10. So it should now be between 60 and 70, so add enough to raise from 65 to 80. The change is small, the exact amount isn't critical, so your way will also work.
    teppy's Avatar
    Nov 2007
    Louisiana
    120
    thanks once again jason. i will do that. i know that the tf-100 kit is very accurate. i like my color q too though. i have been using it for about a year now. i will do both tests sometimes to compare when i need to be sure. the color q and the tf-100 were really the same for the cya. the tf-100 reported 50-60 and the color q gave me a reading of 57. to me that is the same. as a matter of fact all of test results were very close if not exact except for the alkalinity. i never depend on the color q for alk. its always too low. but, TC, Ph, CH, and CYA are just about right on between the two test kits.
    Guest
    Quote Originally Posted by teppy
    Limintation of this test. The higher your FC the lower this test will read once your FC hits about 3 ppm or above.
    teppy's Avatar
    Nov 2007
    Louisiana
    120
    this is just for the alkalinity reading, right?
    Quote Originally Posted by waterbear
