After making remarkable strides through this forum as far as getting my spa jets working again, and balancing the water the TFP way, my last concern is my spa light. The bulb burnt out several years ago, but as no one really used it, it was never fixed. Last year I finally tried to get it out, but the single screw that holds it in place was stripped. I just did a complete drain and vowed to remove the light so that I could fix it.
I did not really want to drill the screw, but had to in order to get it out. I was expecting that it would have additional cord wrapped around the inside so that it could be moved to the pool deck to open it up. As you can see by the pictures attached, there is only 4 or 6 inches of cord which barely allows it to hang out of the niche. As you can see from the pictures, there was about a half inch of mud/rust/algae behind the light in the niche. After cleaning all of that out, and having to refill the pool, I simply put a new SS screw in the slot to hold it in place, but it still needs attention. Of course, the switch as well as the breaker have been turned off for safety. This light was, no doubt, installed originally with the entire pool mid 80s. I believe it to be a Pentair Spa Bright, but the back end does not look like the Spa Brights nowadays. The face plate, though, seems identical except this one has a "pebble" finish and the new ones appear to be smooth SS.
Can anyone confirm my ID as a Pentair Spa Bright? I am not thrilled at the idea of spending hundreds of dollars on a new light, I was hoping to remove it to the deck and replace the bulb and gasket and put it back into operation. After seeing the corrosion inside though, I kind of feel the fixture is a total loss and a new one is in order. Since I did not open the housing, I don't really know how it is wired internally. The thick, grey cord coming out the back probably consists of a few wires that attach to different contact, I presume. Can anyone direct me how best to proceed? I am an accomplished DYI guy and have done all the electrical work around the house. I was just surprised to see that instead of the 4 or 5 feet of cord allowing the fixture to be removed to the deck that there was only 6 " or so.
View attachment 52411View attachment 52412
