The pool is about 30ft holds almost 25,000 gallons. I had the pool crystal clear everything was perfect, then we had a day of bad storms. it blew a lot of leaves and stuff off tress into it. the next few days its was extremely hot in the 90s pretty humid. and algae started coating the bottom. After a day or so I vacuumed it all out, the water got really cloudy i figured it was from me stirring it up. But it never unclouded. and after a few days the algae came back. I put in a decent amount of algaecide. re-vacuumed it all and added a little clarifier. after almost a week it was still about the same with some improvements on the algae. I changed sand in the filter. this whole time i was also struggling keeping chlorine in it. the skimmer constantly has the super chlorine tabs in it from hth, and i was putting several bags of shock in per day it would raise the FC level to about 2 or 3 but within a couple of hours it has back at 0. I bought some liquid chlorinater and added it and it took the levels to normal but not for long within a few hours it would be back at 0. I read online it may be CYA level, i checked it and it was at 0, i added 4 pounds of stabilizer and almost half a gallon of the liquid chlorination and it seemed to do okay at first but i checked the levels before bed that night and it was back at 0. I've never had to put the stabilizer in any pool ive ever had, and kept them all crystal clear. after putting the stabilizer in a week later it still reads CYA at almost zero maybe 1. The water seems clear you can stick your hand down in ir and see it find, but you cannot see the bottom, almost like a slightly blue greenish tint. the algae is coming back a little but not nearly as bad, ive been keeping it vacuumed out. I don't know how to fix it and Ive spent a lot of money on chemicals. I read on one forum that i should maybe buy bleach and put in it.? I've never had this much trouble out of a pool before, always been able to get them to clear up. but i cant do anything with this. I'd much appreciate any help, Ive been using test strips but have ordered a water drop kit, all levels are where they need to be except for FC and CYA.. and ive never worried with the CYA really.
