Thread: Is it normal to see a little bit of sand after backwashing?
    Mar 2007
    Ontario
    211
    Hello,
    After I backwash a see a little pile of sand by the end of the discharge pipe.
    I won't think this is normal. Any ideas why this is happening?
    Thanks
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    Re: Is it normal to see a little bit of sand after backwashing?
    I'm not sure if it's normal, but mine has always done it. When I think about the backwashing process, I don't see how you could not loose a little sand each time. When the water flow is reversed, the sand all mixes around and I'd think for a little to get pushed out with the backwash water would be normal.
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    Mar 2007
    Coastalish 'down easter'
    4,160
    Perfectly normal! 8)
    Luv& Luk
    -Ted
    Mar 2007
    Ontario
    211
    Thanks
