Thread: CYA test mixing bottle
    May 2009
    Hamilton, Ontario
    134
    The label came off my bottle. Can someone tell me how much POOL WATER goes in to get to the bottom of the label so that I can re-affix it or put marks on it?
    May 2009
    St. Louis, MO
    45
    Re: CYA test mixing bottle
    It is 14 ml to the bottom of the label, and 14 more ml to the top of the label, so 28 ml total. However, any measure that is 50/50 will work -- for example, 10 ml of pool water and 10 ml of reagent will work. You just won't have enough solution to fill the test tube, so this may not work if you CYA is very low.
    30,000 galllon, inground, vinyl liner, L-shaped pool
    1.5 hp pump, sand filter, heater, run pump 24/7
    Aquarite salt system
    St. Louis, MO, USA
    May 2009
    Hamilton, Ontario
    134
    Thank you KNIGHTCAP
