Thanks for the response and clarification. I understand that in any drip titration test this is the most accurate way, because by adding that extra drop and then subtracting it from your calculation you know with 100% certainty where the endpoint is. That is fine if all I wanted to test for was FC and end the test there. But I don't understand how this extra drop doesn't affect the CC portion of the test....
What I was inquiring about is what you do afterward when testing for Combined Chloramines. You can subtract that 1 extra drop from your calculation, but you can't pull that extra drop out of the vial. So when you start titrating for your CC readings, you are already one drop into the titration before you even start. (we added it already going one extra drop past the endpoint in the FC test). Don't we need to account for that drop in the aforementioned CC test? In essence if we test for FC in the same manor we test for CH and TA (one drop past the endpoint) wouldn't your actual CC reading always be 0.5 PPM higher than the calculation?
examples:
If after adding my 5 drops of R-0003, solution turns back to pink indicating the presence of CC's...
I tritrate 2 drops of R-0871 to get it back to clear. But I really used 3 drops because one was in the vial already. So reading for CC is 1.5, not 1.0
If it takes 4 drops to get back to clear, it's really 5 drops, so CC is 2.5, not 2.0
Perhaps this is the reason we say that a CC reading of .5 is acceptable, but over .5 is not? Because there is one drop discrepancy?
