itabb
0
Then based on what you are suggesting, I should see a higher CYA level next Thursday, which would be 2 weeks since I added the 60oz. Well, then, I guess I just won't do anything (except SWG and acid as needed), and see what happens. I think I should see a higher level of CYA by Monday if there is still undissolved granuals, wouldn't you agree? So if CYA is higher on Monday, then it takes more than a week to dissolve. If I still see 60, then the CYA I added was at a quarter stated strength (conspiracy). If CYA is less, then something is eating it.
To isolate the test, I should check the irrigation line over a 24 hour period without running the sprinklers to see fill water use. This would make sure I do not have a leak.
