Thread: Auto Ignition on a Hayward H250 Gas Heater
    This is our first year with our new pool and we have used the heater about 5 times. The first 2 times were in late April, and when we tuned the heater on, it ignited within 3 - 5 seconds and had no issues. Recently, the past 2 times, when we turn the heater on, it takes about 3 minutes to ignite, unless, I turn it off quickly, and then turn it back on......it will then kick on within the 5 seconds. I have questioned this with Hayward and I am still awaiting an answer. Has anyone experienced this issue with this unit or similiar?
    Thanks.
    20,000 Gal.
    Hayward D.E.
    I.G.
    All day Sun.
    Aug 2008
    Conway SC
    101
    Re: Auto Ignition on a Hayward H250 Gas Heater
    I have the same issue but i found it to be when i start up the pool on low setting it wouldn't work but on high it would kick on..
    17000 Gallons (16x32) Vinyl In Ground Pool
    Sand Filter
    Install "Finish Date" July 30 2014"
    Propane heater installed.. Used for 1 day.
    City Water.
    Question for you "Sparkmaster"....when you say low or high setting, are you referring to the temperature setting or something else within the control panel/unit? All I have done to date is turn the unit on to "pool" and then set the temperature where desired. Thanks.
    20,000 Gal.
    Hayward D.E.
    I.G.
    All day Sun.
    Sep 2007
    Tinley Park, Illinois
    74
    I have the Hayward H150. I have the same issue. When I turn the heater on with the low setting, it doesn't come on. However, if I turn the dial to "high", it does ignite. Hey, I'm just glad it works!!!!
    24 ft. round Artesian above-ground pool
    54" depth
    15,000 gallons
    Hayward 1.5 HP EC45 DE Filter
    Hayward H150 Gas Heater
