Late yesterday evening, I discovered that I have no power to my control panel. The front of the panel says "Aqualink RS" and inside there are a number of buttons but no model number (that I can find). Knowing what I would find, I tried the web-page/phone-app to see if I could connect to the remote. Of course I was not able to because there was no power.
This morning I went to the breaker box and all breakers are in the "on" position, i.e., not tripped. I then manual tripped the breakers marked "pool motors" (epump and water-fall pump). Checked the control box and still no power. The GFI below the control box works, i.e., there is power, and the test-button trips the breaker.
So before I starting disassembling the breaker-box and the control-box, I thought I'd check with the hive-mind here. Has anyone else run into this or have any ideas as to where to start looking? It's #$%@#^@ hot here in the Houston area and don't want to be out in the sun anymore than I have to.
Thanks
Bill W.
Thanks
Bill W.
