Hi,
I would appreciate any advice on the following situation. I have a very small (12 foot) above ground pool, and suddenly today, while the pump/filter was running, I saw some water leaking from where the return hose enters the pool and then, boom, the plastic type hose popped off and water went everywhere. I reattached the hose and tightened the clamp and everything else around it (nothing moved at all), but as soon as I turn the filter/pump on, the 3 areas marked on the picture below spew water. Spew might be a bit strong, but leak isn't strong enough to describe the water coming out. As you've probably figured out already, I am not very pool savvy, but I am a dedicated BBB user! The pool is 3 years old and hasn't had any problems so far.....
Thanks in advance for any ideas/help!View attachment 49989
