Hello Everyone,
I am currently having some issues with high CC level and dull water.
From Monday thru Friday, my wife is using the 17,000-gallon-pool to deliver exercising sessions to several groups of seniors during the morning. The afternoons are dedicated to children and adults. In a regular day, there are in the water about 12 to 15 people every hour from 7 to 11 a.m. and from 4 to 8 p.m. There are people swimming, walking and jumping all the time in her 8-hour shift.
Current levels are:
FC: 7
CC: 1
pH: 7.6
CYA: 20
TA: 80
CH: 100
Around four weeks ago, on Sunday, I did a 60% water replacement. After that, the CC level was at a more comfortable .5 ppm. Also I started using Potassium Monopersulfate to help oxidization process while keeping FC rather high (above 6 ppm) to prevent a CC arise.
Unfortunately, at the end of the first week I could see that CC level hit the 1.5 ppm mark. This was kind of frustrating since the FC level was kept above the 6 ppm at all times, adding 3 pints of bleach at both noon and night. Every Sunday after last water replacement I have been tossing 4.4 pounds of MPS and enough bleach to reach the 10 ppm or little above, keeping it there during the weekend. On Mondays I get sparkling clean water, but at the end of the day it is easy to see that water becomes kind of dull, clear but no sparkling. I also notice that every morning I get clearer water; I assume this is because I keep my pump running 24 by 7 (@2500 rpm from 7:00 to 20:00 hrs, @1600 rpm from 20:00 to next morning). CC level has been drifting from 1 to 1.5 ppm, but never lower
My theory is:
Under my current conditions, it seems that a weekend-long SLAMMING is not enough to lower CC level or have an OCLT good outcome. Since the pool’s schedule is kind of busy during weekdays, sparing an extra day or two to keep SLAMMING is a costly option.
I am not sure what the next course of action will be to improve water clearness and to lower CC level. Perhaps adding some extra MPS at the middle of the week or add some rpm’s to the pump.
I’ll appreciate your comments.
Thanks in Advance.
Current levels are:
FC: 7
CC: 1
pH: 7.6
CYA: 20
TA: 80
CH: 100
My theory is:
- Considering the number of patrons at one time in the pool; I believe this is a I high bather load for the size of my pool which has to do with both less-than-clear -water and more organic waste to deal with.
- Since my pool is indoor, the oxidization of chlorine by products is slower, implying higher CC readings.
Thanks in Advance.
