All,
Thanks in advance for your help in getting my cloudy pool water cleared up.
My pool is cloudy with a light green tint to it.
Here are my results using the T-100 kit.
CH - 5+ (Not sure how to measure higher as the scale only goes to 5)
pH - 6.8 - 7.2
FC - 2 ppm
CC - 1 ppm
TC - 3 ppm
CH - 275 - 300
TA - 70
CYA - 0 (I did this test many times using several different kits. I can fill up the tube and still see the black dot clearly).
I found a place that sells liquid bleach at 12%-15%.
I dont want to dump it in if I should get my CYA up a bit.
Thanks all for any recommendations on the steps to get my pool into seasonal shape.
pH - 6.8 - 7.2
FC - 2 ppm
CC - 1 ppm
TC - 3 ppm
CH - 275 - 300
TA - 70
