Here's my plan, wire a Stenner 45MPHP2 (fixed rate - 3 gallons per day) to run with the filter pump. I have the pump timer set to run 6 hours a day so the 45MPHP2 will put out 3/4 of a gallon or 96 ounces per day. I only need about 24 ounces so I'll add 3 gallons of water for every gallon of chlorine. Am I on the right track?
The other question is what tube to use. Black/white 1/4" or 3/8"
