I purchased an AQ-TROL-RJ-TL. Hooked up easily and manual says it does not need a flow control since it's a return jet and it being vertical.
I cannot get it out of no flow error code. I called Hayward support a couple days ago and she said I need to check the AL level under diagnostics. It should be at AL-7.
It was set to AL-0 but I can only go up to 5.
I emailed them back and no answer yet and they are no open today (saturday).
I was wondering if anyone knew the phone jack wiring for the flow switch. I could just create a jumper cable and close the flow circuit so it thinks its on. I can't find a wiring diagram anywhere.
I just opened my pool and didn't buy the usual amount of bleach thinking I would be using the AQ to generate. I bought a case yesterday and I'm almost out. Yes lots of algae right now. I will have to get another case or 2 until this gets fixed.
Maybe that Amazon warehouse deal ($435) wasn't such a deal afterall!
Rob
Rob
