I have a small question. I have a complete new pad. I must still have air comming in from somewhere but its really minor. Most likely the new pool super pump gasket. I lubed that up with magic lube and it still shoots some air in the pool. The multiport is also new. Do I need to lube the spider gasket in the multiport and then lube the oring where the bolts are? I would not think i would have to since this is a new system?
My next option would be to have the pool place come back sometime this summer and pressure test it out as they are the ones that helped install everything. I learned a huge amount when we took the guts from my sand filter and found some brokern parts. We put all new inside of it except for the lower tube and put new sand and pea gravel in this succer.
Maybe I am just being a bit anal and when the water warms up, maybe the seals will expand enough to seal themselves up?
What are your thoughts guys? Thanks
