Hi Guys,
Opening pool yesterday color lime green. I added 4 jugs 121 oz 8.25 bleach. Color turned clearish cloudy after a couple of hours. I also vaccumed the bottom blindly, not much big stuff but lots of gunk. Hooked up filter and got it running while adding some water. Then I tested the cloudy but clearer(I can see a hazy bottom) water.
CL-8
TA-200
Cya- 50-60 (after 3 readings it is between the two numbers)
PH- 8.2 or a tad higher
salt 2840
water temp- 72
So we added approx. 363 oz bleach last night kept filter running and retested this morning
CL-17
cc- 1.5
TA- 200
PH- 8.2
water temp 68
so I added 151 oz approx bleach according to pool math
So here lies the questions... Plugging in my numbers I see I need to add 46oz MA 39oz CYA(stab.)
Should I add a little less CYA and retest in a week to see where I stand??
Should I add more salt with our salt water generator saying we need 2500-3500 with 3000 be ideal.
We are at 2840 on the salt test strips from the TF100 kit people.
Thanks for your help
Lisa
intex 26ft 14667gal... intex sand filter... intex salt water generator(which is not hooked up yet)
in North Central OK with 2 big trees Sycamore and Pecan nearby
CL-8
TA-200
salt 2840
water temp- 72
CL-17
cc- 1.5
TA- 200
PH- 8.2
water temp 68
Lisa
