I've had all my equipment setup for a few days now. I've had the Intelliflo in manual mode running at 45GPM and my pool has gotten very clean and clear. Last night I added 1200 lbs of water softener salt to the pool. This morning most of it seemed to be disolved. So I went ahead and connected the two connectors to the pool pilot. (On a side note, the connector that goes onto the cell seems to go on either way, is this correct). Right away the pool pilot showed to add salt. It showed purifier off and the status light was blinking. I went thru some of the menus and I setup my pool volume (46,000), I setup the programming for a single speed pump and setup the cell for the DIG60. The display still shows purifier off and the status light blinks. Now the add salt is showing 738lbs.???
Any ideas? #1 - Why is it still showing purifier off?? #2 - why does it think I need to add 738lbs of salt after i've already added 1200lbs?
