Well, this really bites.
is there a better way to measure CYA than the disappearing dot method? Something that changes color? If I am doing this right, my CYA is still over 200 after 2 3-foot drains. That either means my CYA was over 400 when I started this, or I'm just not reading the CYA right, or draining is not lowering the number. The other issue may be I'm not taking enough water out, but everyone has told me not to let the drain go beyond my shallow edge. My wife will not let me do another drain, because she believes the pool store, and not some site I found on-line. She wants me to stop draining, and just keep shocking until it clears. So, I have a few more questions.
Could my CYA have been over 400, or am I not just lowering it by draining?
Since I am pumping out water after the filter, and all the algae is staying in (just getting more concentrated as water goes out), could this be the issue? Could the DiChlor (source of my CYA) be attached to the algae somehow, and not exiting when I am draining? If I were to drain again, I would remove the filters and pump out algae thus time too.
Is there a better method to measure the CYA? Could I just be wrong about the number?
What is the reason for not going below the shallow end when draining? If you look at my avatar, you can see the pool in the picture and the shallow end is to the right in that picture, and not that large. Most of the water is in that deep end, so I'm not even sure what percentage of water I'm removing. If the concern is the liner can come loose with no water in it, could I carefully add weights to keep the liner in place in the shallow end once the water level goes away?
I need to get this CYA under control, or the wife may kill me. She is having Knee surgery the end of June, and can't use the pool for 5 weeks after. So, she wants this open now, so she can get pool time in as soon as we have nice weather. Once I get this fixed, I will have to look at replacing that DiChlor auto-feeder.
