I have a question on liquid stabilizer. I opened the pool yesterday and basically have a CYA reading of 0. (In-ground vinyl pool.) I use a mesh safety cover and partially drain the pool each closing and it gets new water throughout the winter, but there's usually some readable but low CYA level.
I just got back from buying the usual dry crystal cyanuric acid, (didn't add it yet), but now I'm thinking I should have bought the liquid stabilizer I saw in Leslie's just to get it dissolved right away. Aside from cost is there any other negative to using the liquid vs the dry?
Will the CYA readings using the Taylor tests kits still be accurate? (I saw the liquid is a salt of some kind and I'm not sure if it becomes CYA once added and if the CYA test reagents can still read it.)
Thank you.
Thank you.
