My pool is under construction (you can read my Introduction post).
The PB installed the inline Chlorinator with a U shaped loop with a 90 degree bend that goes into the ground after the chlorinator and then loops back above the ground to the valves that lead to returns, bubblers and deck jets. The PB says he does this on all pools now to keep the chlorine from the dissolving tablets from entering the pool when the pump is off. The pool is about 50' away from the equipment pad.
I wanted good plumbing and this U loop seems restrictive. I probable won't even be using the inline chlorinator after a year and will go to liguid chlorine (BBB) or SWG.
The inline chlorinator was to be a Pentair Rainbow brand but he substituted an Aquastar Super Pro and he says it is a Rainbow. They do look the same.
Appreciate any comments & suggestions. Thanks.
