So far so good! Started with green pool, now it is blue and can finally see the bottom! Still have some hazy cloudiness there, so continuing the SLAM. My levels are below, been focusing on Chlorine and CYA should I run other tests? Could anything else cause cloudiness during SLAM or just keep going?
FCL 15 (I added to go up to 20 per chart)
CYA 50 (think I over stabilized last time)
CCL .5
Got my k2006 test kit and have been testing my buns off, I feel like Walter White. Question though on the fas-dpd. When I add it to the water there is always some clumps at the bottom that don't get mixed in. Is that normal and should I try to fish them out before putting the drops in?
Thanks!
Sent from my SM-G935V using Tapatalk
CCL .5
Thanks!
