Thread: CH for IG Vinyl pool with fiberglass steps
    Mar 2009
    Huntsville, AL
    156
    I'm a new pool owner with a quick question regarding the correct CH level for vinyl pool with fiberglass steps. I've been ignoring the CH thinking it didn't matter with the vinyl pool, but saw a post the other day that reminded me of the steps.
    My readings today (after 6" of rain this weekend) are:
    FC = 5.5
    CC = 0
    pH = 7.6
    CH = 110
    TA = 70
    CYA = 55
    Salt = 3000 at the SWG & 3700 by strips (I'll be asking about that later...)
    Thanks for your thoughts,
    Gordon
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
    Re: CH for IG Vinyl pool with fiberglass steps
    Fiberglass can use some CH, though the reasons are not nearly as critical as the ones for plaster. You can help the fiberglass last a little longer and be less likely to stain if you raise the CH to the low end of the fiberglass pool recommended levels.
    Mar 2009
    Huntsville, AL
    156
    Thanks Jason! I'll bring the CH level up right after this next batch of thunderstorms blow by.
