I recently changed the diverter on my pentane top mount valve. I'm thinking that since putting it back together that it may not be going thru the sand as my pool is not cleaning up. I've back washed, filtered and everything seems to work fine. While back washing & rinsing the psi runs about 10psi and when I switch to filter it jumps to 14psi which to me would indicate that my water is passing thru the sand and that the diverter valve is functioning correctly. Would anyone have any pointers or helpful information? I am currently in the process of bring my pool FC back to shock level (10) and beginning the SLAM process again as my water is staying cloudy.
FC 4
cc 1
Cya 20
Ta 70
PH 7.4
FC 4
cc 1
Cya 20
Ta 70
PH 7.4
