Results 1 to 10 of 10
Thread: DE Air Valve
    DE Air Valve
    As most of you know I tackled my DE grids this past weekend.
    I have picked up my scoop, new media and lube for O ring. I am ready to get filter back up and running. However, I am missing an air release valve on my DE. Pool store says that I HAVE to have one. Help! What should I do?
    Steph
    18k Gl, Plaster Pool, Magnetex Pump, Haryward MultiValve, Clear Flo DE Filter, 220 Volt 2 phase timer #T104P by Intermatic.
    Feeling better about my pool, thanks to TFP and the gang!
    Re: DE Air Valve
    I have never seen a DE filter made without an air release vent. You do need to have one.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: DE Air Valve
    By rights there HAS to be one, but someone in the past may have made it inoperable Any chance of a few pics of the system, especially the top of the filter?
    Luv& Luk
    -Ted
    Re: DE Air Valve
    Pics are no problem...
    Just to the left of the valve there is a clear site glass, can anyone tell me what that is?
    There are two pressure gauges, but one hasn't read any pressure at all. Is it possible that someone replaced the air valve with a gauge? If so, Is it possible if I change it back?
    Thanks everyone!!
    Apr 2008
    Central Texas
    326
    Re: DE Air Valve
    Looks like someone removed the air valve. Perhaps the valve broke and someone plugged the hole with an old gauge? Kaptain Kluge in action! Looking closer, I would guess that there is an entire assembly missing from the top. My DE filter has a plastic housing up top that contains the air release valve and the gauge screws into it.
    In any case, without an air valve, water can never fill the tank, so only part of the filter will be working. You need to bleed out the air in the tank, while the filter is in operation. Once there is water coming out of the valve, then you can close it. Unless you have a leak, it only needs to be done after you backwash the filter or open the housing for a thorough cleaning.
    The sightglass near the valve is just there so you can tell when the water runs clear while backwashing.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    Re: DE Air Valve
    It should be fairly easy to find an air bleeder valve at a pool store. That is a fairly standard threaded hole, so it shouldn't be difficult to find.
    Re: DE Air Valve
    So should I look for the whole thing, or simply add an valve where the second guage is?
    Re: DE Air Valve
    Remove one of the gauges and install an air bleeder valve in it's place.
    Re: DE Air Valve
    Great thanks Jason. I will remove the gauge that I have seen no pressure on.
    Hope that works and get me up and running again.
    Re: DE Air Valve
    I went by Lowe's and picked up and air release valve last night. Removed the gauge and replaces with the valve. Tonight I will hopefully get the pool circulating again. We have had a LOT of rain here within the past week and more expected this weekend. I am hoping that I will not see to much of an algae bloom when it stops raining.
    Steph
