Hello All. I did a Compool to Easy Touch upgrade and few months ago and all is good with that, except for the fact that I had to re-use the 20 year+ original Compool relays. A couple of the connectors that attach the relay coil to the Easy Touch PCB, due to age and flexing have become intermittent and may or may not actuate the relays. After a good deal of searching I finally found the correct replacement connectors. A lot of searching the Molex and AMP catalogs for the connector did not bear any fruit. I finally used an eyeloop on a 2 pin header on the PCB board and found that they were JST connectors. Some more searching and found out that they are part of the JST XH line of connectors.
Here is a link:
https://www.pololu.com/product/1164
I ordered some of these and they are a perfect fit. Hope this helps someone in a similar predicament.
Here is a link:
