jerzeyrep01 said:ok so i have added 4lbs of baking soda to now have a reading of 50.
I have also taken a TC test in the am and one after i got home from work monday and today.
Mondays reading were 3ppm in the am and 1 ppm in the afternoon
tuesdays reading was 5 ppm in the am and 2 ppm in the afternoon
does that sound good? and how much higher do i need t/a at this point? when should i test for cya again i added about 2.5 lbs on sunday.
That sounds like a normal FC loss for daytime with little CYA in there. You can test for the CYA on Friday at the earliest...In the meantime make sure your morning FC is about 6 so that the FC doesn't drop below 3. The TA is recommended levels of 70-90 so you're almost there! It does sound as you are doing the TA test correctly.
