Hello all. I am considering changing my Maxi Glass 2 pump to a Pentair Intelliflow VS pump. Is the height from the ground to the middle of the inlet port on the VS pump the same as the Maxi Glass? I don't know if there is any kind of standard for this dimension or not. I only have about 4" of pipe from a 3 way valve to the inlet of the Maxi Glass, so not a lot of room if the height is not similar.
Thanks!
Thanks!
