Doing a quick calculation your pool holds upward of 200,000 lbs of water (assuming 4' of water depth). With a known efficiency of most pool heaters in the 80% range, your heater, at best, will return about 104,000 BTU's of water to the pool. With that, you will see about 0.5 deg F of temp rise. Not very good if you need to change temp quickly. As was mentioned, you should have a 400,00 BTU heater. This will give you close to 2 Deg F temp rise. A little better for quick warmups. The down side to the bigger heater is the installation costs. You will most likely need a bigger gas service to supply that size heater.
