- Apr 25, 2008
- 6
I have read this forum for several years and it has helped me with numerous questions about doing my own pool. Now for my first question.. I installed an aquarite SWG over the weekend and when I did it I cleaned up all the plumbing. replaced all the valves, rearranged the equipment for a neater look as I inherited all this from the previous owner. I am attaching an old picture of the equipment just so everyone knows what I am dealing with. it does not look like that now.
So I fired up the pool, balanced the water, added salt, everything seems to be working great and no visual water leaks anywhere. The pump will run for around 6-8 hours and then lose prime, I go out there and notice nothing is coming out of the return jets, so I shut the pump off and then just turn it back on and it takes off again.
I did notice that when the pump is under pressure and I shut it off I get a squirt of water out the side somwhere, So my game plan is to replace the strainer lid gasket and do a more visual look of where the water is coming from, also after reviewing this looks like I need to teflon tape all the drain plugs on the basket.
I also noticed when cleanign I do not get a real good suction on the vacuum - are both these issues related?
also on my DE filter when I took it apart I noticed alot of hairline cracks in the top collector, is this something that needs to be replaced immediately?
Thanks for everyones years of help and they didnt even know it..
Jason
Jason
