- Oct 25, 2015
- 5,200
- Plaster
- CircuPool RJ-60 Plus
100% Agree!
The problem here is inconsistency. Inconsistency in testing and inconsistency in pool care.
CRB,
You sound like someone who has to travel a lot (either for work or family) and it sounds like you are not able to care for your pool on a consistent basis. It has been said before but I will repeat it - The TFPC Method of pool care requires daily attention to your pool. It may not be more than 5 mins/day adding some chlorine in the morning and testing at night, but your pool requires it if you wish to practice the TFPC Method. There are no shortcuts.
Given your schedule, I believe you should seriously consider either installing a Stenner pump to automatically deliver chlorine everyday or a salt-water chlorine generator. Either of those automation options would be far and away much better for you and your pool. I know it is a significant investment upfront to make but, as it is now, you are wasting your money having to constantly SLAM your pool and keep the chlorine high because you can not consistently dose your water. Honestly speaking, even hiring a pool service company to take care of your pool would be better than what you are going through now.
As Casey said, there's nothing to do about it at the moment and even if the pool is green when you get back it's not hard to fix. But I do seriously urge you to consider getting some kind of automation on your pool.
Good luck,
Matt
Matt,
Thanks so much for the candid and direct input. That's actually a great idea and I'll look into it when I get back. I was actually hoping my schedule would get more by now as I really like to do the testing and pool care. I can at least get the info in place if I need to automate.
Chris
