Hello, I'm in need of some help/advice regarding the pump/motor on my spa { I posted this in the 'Pumping Station' section but didn't get any replies (I think I posted in the wrong area)... So I figured that I'd try here. }
My spa just started sounding really loud recently. The spa manual says to "Clean the suction" and/or "Open both valves", but I'm not quite sure what that is.
I took a video of it so you can hear what it sounds like:
Noisy spa - YouTube
Does anyone know if it's the bearings, motor, belt or maybe I need to "lube" the "O" rings??? If it's the pump, should I replace it?
If anyone has any advice or can help, I'd greatly appreciate it.
Thank you so much in advance.
LM
Noisy spa - YouTube
LM
