I see that Ag pools and swg don't mix well. Is there anything I can do to slow down the process of the salt corroding the metal when the water spills out on the sides and hits the bottom of the pool wall?
I'm attatching a wall foam and bottom foam, in case that matters. Should I wrap the putside with anything? Maybe pitch the ground down away from the pool? I'm guessing that's not wise to do.
Should I spray it with something before I assemble it, or after I assemble it? Maybe grese it with something where it touches the ground?
Anyone do anything like this?
It is a metal and resin pool mix. Just a few resin parts. Not 100%. Walls are defintely steel.
