Hi all, got my TF100 and was hoping to get some thoughts on my numbers and what I should fix first, second, etc.
FC 9.5
CC 0.5
PH 7.2
T/A 130
CH 1,200
CYA 100+ (never reached a line on the tube)
Some background;
Before my TF100 arrived I had an algae bloom (grren algae but could see bottom of pool no problem) and used the granuals I had to raise the chlorine level to kill it. I also have 2 floaters each filled with 4 pucks that I have not yet removed from the pool. I have read, re-read and read again the pool school and am now comfortable to switch to bleach until I install my swg, I have several adjustments I need to make to get in balance and am wondering what I should adjust first, second, third, etc.
Also I'm not very confident my CYA level is right due to the water temp (too cold?). I don't have a number on my water temp (So Cal area). CYA was the last test I did, but I'm not sure the few minutes I took to do the other tests was enough time for the water to reach room temp.
My water is clear, I do see a "scum line" in places where the water meets the tile and there is no more algae. If it matters my tap water CH tests at 200. Thanks and I hope I provided enough info.
FC 9.5
CC 0.5
PH 7.2
T/A 130
CH 1,200
Some background;
