Results 1 to 8 of 8
Thread: clogged pipe
    clogged pipe
    Ok..I know the rules and I tried to follow them. I searched and read a few responses, but nothing has helped. I see that there are 14 registered users on right now so hopefully I can get instant help. I bought a new G3 Baracuda for my pool....it's been working great, but now it seems like the "pipe" from the skimmer basket (where I plug in the vac) to the pump is clogged...barely any water moves through and of course the vac isn't working. I do not know how to clear the pipe. I know that there are TONS of leaves in the pool, we have been working round the clock to clear them out (also working on the legality of cutting down the tree hanging over it)....any help? I'm wondering if there is a way to push water back through it?? Really dumb with pools, just know basics...help?
    SuzanneMomof3
    Southern Florida
    First time In-Ground Pool owner (plaster?)
    Not sure on size (measuring soon)
    Rectangular, 6 feet deep end
    Pool in full sun all day (lately lots of rain)
    Salt Water Generator Zodiac L3
    Hayward Filter, 1 HP pump
    Hating the automatic vacuum we currently have
    thinking about buying a Zodiac Pacer or G3
    *not sure what else to put here* :)
    chezhed's Avatar
    Mar 2009
    Mission, TX
    37
    Re: clogged pipe
    I can offer some ideas but I have no idea how realistic they may be...
    1) Do you have a valve that will allow you to shut off the main drain and simply pump from the skimmer? This might be enough to make something move if it is in there.
    2) Own a plumbers' snake? Snake the pipe...depends upon the length and bends I guess. Maybe an electrician's fish tape...
    3) Reverse the pump motor wiring and run it backwards...I'M KIDDING I don't think this would be a good idea but it would reverse the water flow
    11,000 gal + overflow spa, IG gunnite, Pentair 48FNS DE filter, Hayward SP3210X15 pump, CompuPool CPSC36 Chlorine generator, pool valet w/5 zones, Pentair LP heater
    Re: clogged pipe
    Thank you! I did number one....even switched back and fourth, but didn't work....I will have to go and get something to snake it out with I suppose....I'll report back after trying!
    Thanks again
    SuzanneMomof3
    Southern Florida
    Re: clogged pipe
    The first place to check is the pump strainer basket. Too much debris in there will slow down your circulation dramatically.
    Another thing to try is to get a drain king, an attachment for your garden hose used to clear clogs. Open up the pump strainer basket and remove the basket. That should allow you to fit the drain king into the pump intake pipe. That might be able to clear the clog.
    chezhed, changing the wiring on the pump will not cause it to run backwards. Pool pumps have AC connections, which can be hooked up either way.
    Feb 2008
    Dallas, TX
    60
    Re: clogged pipe
    Speaking as someone who has run their motor backwards ( accidentally, course)... DON'T DO IT!!
    The motor unscrewed itself from the impeller, the impeller ran into the pump housing, the motor shaft then cracked the back side of the motor housing (The foot bone's connected to the leg bone ...) . See this thread http://www.troublefreepool.com/buste...ain-t5357.html.
    If there was any reverse water flow, I really didn't notice. Good luck with the clog.
    31000 Gal IG L-shape w/ spa, Riversand finish (PebbleSheen clone)
    Jandy 60 sq ft DE, 2.5 HP (uprated) Stealth pump, Polaris 280 w/ booster, Jandy PDA PS4 controller
    chezhed's Avatar
    Mar 2009
    Mission, TX
    37
    Re: clogged pipe
    Well, duh on me thanks....said I didn't know how realistic I'd be
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: clogged pipe
    Quote Originally Posted by jkalan
    How did you manage to do that? Back pressure when you were turning it off and back on again? That's the ONLY situation where a reverse-threaded impeller screw helps and I've never seen it happen.
    Feb 2008
    Ohio
    156
    Re: clogged pipe
    don't feel bad, I did almost the same thing just a few days ago
    I got my clogged skimmer line to clear by shoving a garden hose into the skimmer, snaking at the pump connection (my clog was right near the pump line, luckily) and had to snack it for awhile to loosen it up and then finally shoved in a wet vac (pump line side) and just kept at it..
    I also made sure the pump basket was clear (I tried just shutting off the main drain but, it wasnt enough water pressure).....once I went with the above route it unclogged in about 20mins (the snake I used was just a bent wire hanger)
    I have a connector that you are suppose to be able to unscrew (which would have gave me access to the clog) but, I couldn't get the darn thing off.
    good luck
    Chris
    30-40yr old prehistoric IG gunite 20 X 40 approx 30000gals
    now with new cool blue Diamond Brite and blue waterline tile (looking good for 40yr old pool)
    new Hayward 244T sand filter, 3/4 Hayward pump, Jandy heat pump
    pool skim (love it)
