Hello, just finishing my pool. plastering was 7 days ago. I have a pool table. I recently discovered that the bottom surface of the table (concrete) was not plastered. it is uneven and pitted. I spoke to my PB and he said he builds them all this way and there is no problem with it. He said you can't see the bottom so there is no cosmetic issue.
I am concerned that the pool table will deteriorate with time as the concrete is not sealed and I have a salt pool. The bottom surface will be in water. Can concrete leach elements into the water? How do we correct this other than to partially drain the pool, but I have new plaster, how long before this can be done, and not damage the new plaster?
Any thoughts would be appreciated.
