Loved the stickie about bromine and spas! Great info, but not anything close to what I've done with my pool after 13 years of bromine. I just put the pucks in the brominator and I've never had a I problem.
Now I have a new grand rapids inflatable spa coming, and I've never looked after a spa before so I'll need to learn the ins and outs.
I will not use the spa when the pool is open (summer) but fall/winter/spring, yes. I'm near Toronto so winters are well below freezing.
My plan was to fill the spa with the pool drain hose, and by doing so transfer clean brominated water to the spa, and ready to use. I assume the first fill will not need sodium bromide for that reason, but subsequent fills of course will need that base.
When it's time for a drain and refill in a few months, was considering emptying the tub into the (closed) pool and refilling from the garden hose. Then following the bromine spa stickie to set it up from there.
Just curious if anyone thinks this is a good plan or.......
Sent from my Nexus 7 using Tapatalk
