I know this is an old thread but there's some good info in here. I recently bought a Saluspa Paris and want to take it into the Winter. Our winters can get brutal but this one is in the (unheated) garage so at least it has some shelter. I figure I can still enjoy the snow coming down with the garage door up....so this is a blend of indoor/outdoor. What I like is not getting all the leaves and debris in the water like the pool does outside.
Ok onto the heating and insulation. I did put some cheap 3/4" foam board underneath the ground cover, hopefully it's adequate. You would think so since the floor is already padded but only time will tell. I'm planning on wrapping some fiber glass insulation around the outside because this spa has that return line that runs along the outside. The lid I'm still wrestling with how to further insulate it but I did put double sided reflectix to use as a floating blanket, then lay the inflatable lid on that. It probably wouldn't be a bad idea to lay some foam board insulation on top of the reflectix then top it off with the air lid.
As far as generating more heat I want to do the tankless water heater mod but just pull the water directly from the pool into the heater using a flow jet type pump and have it go straight back into the spa. If those things can actually raise the water temp 2-3 degrees per minute I'll be extremely happy. That way I can set the spa temp for maybe 90 degrees and let the camp shower heater take it the rest of the way.
