I am in day 2 of my first SLAM. The water was already pretty clear when I started but the FC was non existent and the CC was 1.5, so I decided to SLAM. I have added about 20 bottles of 121 oz bleach over the first two days. And if each bottle is raising my salt by 13, then that might be why my salt numbers are high. Currently my salt value is 3600 on my panel and 3800 when I do the test myself.
Since my SWG chlorine percentage is set to 0, it is basically off and the excess salt won't hurt it, right? So should I continue the SLAM and then after it is completely done, fix the salt value then by draining some water and adding some new water?
Just want to make sure I am doing this right. Also, does 20 bottles of bleach sound bad? Seems like a lot but I'm using the pool math calculator to help me figure it out.
Thanks as always for the help.
