I have a 10,000 gallon IG pool. It is a SWG. According to the manual the level needs to be maintained at 2700 - 3200 ppm. My controllers shows it at 2600 ppm over the last two days. I do I determine how much more salt I need to add? :?:
JohnT said:Go to poolcalculator.com, but I'd recommend you verify the reading with test strips before you add too much.
Butterfly said:Pretty sure AquaChek salt strips are a favorite around here.
If you can't find them locally, check with Dave (duraleigh) at TF Test Kits (link in my sig & on home page).
