Good Morning! Has anyone used a Yolink Smart Relay replace your pump timer? I haven’t started researching how one might set that up considering this is not 240V, however I’m sure there is a way to have a series of relays that would allow for this to be the Master relay.
Would be great if this would work as I use YoLink to automate anything from heat lamps to pool lights. Thanks!
YoLink Relay, YoLink 1/4 Mile Super Long Range Smart Relay Compatible with Alexa, Google, and IFTTT, Max. 5 amps - YoLink Hub Required https://a.co/d/3EDnZ5S
