- May 12, 2012
- 191
- Vinyl
- Pentair Intellichlor IC-60
I have researched for quite awhile for info on leaking multi port valves on this site and didn't find anything exactly like my problem. I have a Pentair MPV Model #261055. I have seen a bit of water around handle at times but not consistently and thought it could be from rain/sprinkler, etc.; however, what I have noticed is water leaking from around one of the screws on top of the valve cover. Called Pentair and they said it probably needed new O ring. Just looking for confirmation as to if this is probably the fix for my issue. If water is actually leaking around the handle, would that also be the fix for that as well?
Thanks for all your help.
