Hi all,
I've recently drained and filled up my tub about a month and half ago. The water was properly balanced then and I've only used the tub twice since. I use bromine cartridges and keep the pH in between 7.2 and 7.8. The last time I used the tub was probably 3 weeks ago. Since then I have been away and haven't been able to test as often. I do have the Frog bromine and mineral cartridges in the tub so I haven't thought much of it until today.
I checked the pH it was low. I added 3oz of pH increaser and waiting to test again, the bromine levels seemed low (the cartridges were empty!) and the water started looking cloudy. I've also noticed a yellow ring has started to form around where the water sits. The tubs temp was set to 95*F and it goes through 2x 2 hour filter cycles daily.
Does anyone have any idea what the yellow ring is? I've attached a photo. The water has also become very foamy and forms bubbles when the air jets are on. The water never became this foamy or bubbles when I replaced the water.
I've just added some pH and some extra chlorine while waiting.
Thanks
Thanks
