I literally signed the contract to have my pool built a year ago- May 4th to be exact. I retrospectively understand my pool is not your simple build. There have been many concerns as a pool as small as mine should not take a year to build but I will get to the point...
I was away on vacation last week and came home to thankfully work done on my pool- it was plastered, with marcite/plaster? I am a newbie, sorry. There was water being filled from my aquifer well into the spa. It was taking quite a while and the water was not filling as I expected. Sure enough I looked again and the pool/spa pipe connections (on the other side of my house at my request) was leaking all the water (no pool equipment had been attached and the pipes were open ended. I do not know if this was due to the plasterer or contractor as I was not there. I texted and called my contractor and he responded 3 hrs later to turn the water off and he would be there in the am. I had moved the water from the spa to the pool as I read once the marcite/plaster is done it is imperative to fill the pool evenly and quickly. He said to turn the water off so I did but the pool had about a foot of water by then. I did not see him come today (Sunday). There is an obvious line where the water was. Am I over reacting or should I be worried that there is a permanent stain? Tomorrow is Monday and a work day which I will be home for and hope to resolve this. Thank you for any help.
Once again I am new but I hope this info helps...
Inground pool with fill dirt added, negative/infinity edge, plaster, artesian well water used for partial questionable fill, no parameters in water quality, location- NE Florida. Pool size, 16' (with overflow of water, 14' without) by 28'.
