One expects a certain amount of trials and maintenance when owning a pool, and to a certain extent....I've done alright with my 7.5 year old backyard in ground masterpiece....
But, the mysteries of keep chlorine at reasonable levels during summer months here in San Diego are a constant chore.
I'm on my 2nd IC60 now, controlled with intellichem, and am exploring options before just replacing it.
The first IC60 died after 3 years, probably because I had it on too much. The 2nd has lasted 4 years.
The IC60 is probably on for 2-3 hrs/day during the winter and 12hrs/day during the summer (assume ~2600 hrs operation/year). And, yet for at least 4 months a year, I'm having to manually add 1-3 gallons of chlorine/week to the pool to handle summer UV rays and higher temperatures. The pool stays around 87 degrees from June to September and can peak at 90 degrees briefly in August.
CYA stays around 50 - I push it higher sometimes.
We do have an intellichem, but I don't pay attention to the ORP probe and have the SWG running on a fixed time on/time off schedule.
So, I'm wondering how I can improve things.....I could run the pump and SWG longer, but to keep 30 GPM that the SWG, Acid Dispenser, and skimmer seem to prefer, and to be conservative in case the filter needs cleaning, requires a pump RPM of around 1600-1700 which consumes 250-320 watts. I'm not sure I want that 24hrs/day. I might be able to bring it down to 1400-1500 rpm.
I'm not even sure if the IC60 is still the SWG to go with ....I'm stuck with pentair system so perhaps. The intellichem would support adding a chlorine canister to it, which might simplify the summer months....
What would you all suggest?
I should add that I shock the pool once/twice a year...and I do occasionally push the CYA to 60...but the intellichem isn't happy and I do tend to lose CYA quicker than expected. I found two leaking pipes/valves in the last year. Salt is kept between 3200-3700 according to the SWG.
