Replaced old pool pump with new Pentair VS 342002 pump. To get pool running I disconnected the old pump and reconnected new pump and turned on the breaker. Everything is running but I have a question concerning rewiring the pump in the panel. My old pump was a single speed that was wired to a T104 timer, which is wired to another T104 connected to my polaris booster pump. These are both connected to a 2 pole 20 amp breaker non GFCI. I know current codes call for GFCI breakers. I need to buy a GFCI for the new Pentair pump and from forum it should be a siemens PA220GF 20 Amp 2 pole. I assume that I remove pump from the T104 and wire direct to the GFCI, correct? Then I'd remove the first T104 and wire and keep the polaris wired to the T104 timer and wire it direct to another 2 pole 20 amp breaker.
