- Oct 8, 2020
- 543
- Plaster
- Jandy Aquapure 1400
Hey folks, I still haven't hit my first anniversary with my pool yet (it finished March 2023) so I haven't really had to go through a full winter experience yet. I wanted to take a moment to make sure I'm prepared for a freeze, if it does come. Last thing I want to do is panic and not know what to do.
I did find a few threads about preventing equipment damage due to freezing weather. I'm in Dallas, Texas so I don't really winterize my pool. I have (and plan to) kept it open all year so far.
I have checked freeze protection in iaqualink and the following are programmed to come on: Filter pump, spa, cleaner, slide, bubblers, sheer dscnt
I feel like I can turn off a few of these, but I want to check first:
I have a feature pump that controls the slide and sheers. I heard that it's best to just drain the feature pump and turn it off during the winter. But I'm not sure if this is necessary. I assume the exposed pipes won't have water in them this way. If this is recommended, I can remove these 2 from freeze protection. This will also affect some scheduling since I currently have the feature pump turn on for 5 minutes every morning (this is just to keep them flushed out).
I'm not sure why Cleaner is enabled. I read that since it is tapped into the filter pump returns that it always has water moving through it anyway, so I think I can tick this one off. Pool builder probably had it set up this way. So far I've kept my cleaner schedule (2 hours daily in the morning) on. I was planning to keep it on all year, but if I should turn it off in the colder weather let me know.
Bubblers I think I need to keep enabled since that's at least 1 exposed return PVC that could freeze.
I also read that people wrap exposed pipes with some shiny insulation stuff from home depot. Should I do this? I was planning to paint the PVC for protection from UV during the summer, but this might work as a substitute for that which also helps in the winter too, right? I also saw people use tarps but not sure if I should do that with a heater and running equipment? The heater we sometimes use for the spa.
For skimmers, I heard people stuff pool noodle pieces in there. I'm not sure if this is only for people that close their pools.
Anything else I'm forgetting that would help me be prepared for another Texas "snowmageddon" or just long freeze in general?
