I am hoping to vacuum to waste by removing the filter and disconnecting the return if the algae settles to the bottom. I removed the filter in order to prevent filter clog up during the algae cleaning process - i have a cheap above ground pool (~1400 gallons of water) from big box store that has just the little dingy filters. I unfortunately got too busy to maintain thus the water was dark green.
I lowered pH using muriatic acid and poured bleach ~25, now water is a much lighter green color. I am maintaining the FC at high level. Do I need to lower pH before adding more bleach once FC goes to zero? I have some clarifier laying around I will also use that once I can vacuum things up as well.
