Hi all, just looking for some expert opinions on a new pump option ......
Our current pump motor seems to be showing signs of failing soon . Starting to run louder, Starting to run hot . Too hot to keep my hand on it for long if its running for more than a hour or two. Seems like a new pump may be in the cards soon . Pump in question is an 1.5hp old school single speed energy hog .
I can go with just a new motor, the cheapest option . Or maybe upgrade to a VS pump .
Here is my dilemma .....
I would really like to go with a quieter VS pump . Looking at the Pentair Superflow VS . https://www.pentair.com/content/pentair/en/applications/enjoying-water/pool-spa-equipment/pool-pumps/superflo_vs_variablespeedpump.html 1.5hp , 110v or 220v (I have 220v) variable speed with programming right on the unit. Approx $700.
Want a quieter pump that will save some $$$ on electric. My problem is I am not sure if it will work for our pool application .
Pool in question is a 18x36 , approx 25,000 gals . Very simple set-up . No water features, no floor drain . Just a single skimmer to pump , that splits into 3 returns back to the pool after the pump, filter and ........... heat pump heater . NO SWG , running a nice Stenner system for chlorine delivery , so not stuck on long run times for that , but I need to run the pump for the heat pump heater a few hours a day .
My question before I shell out the bucks for a VS pump , is if the heat pump heater can handle the slower flow without shutting down ?
Heat pump in question requires 25GPM for a low , and 80GPM for a high . works perfect now with a single speed 1.5 . Putting out tons of flow out of 3 returns to the pool .
Is 25 GPM still achievable with a VS pump at the lower RPM speeds ? I would be happy, if even half speed would be workable.
Anyone have any advise on this ? I am thinking 25GPM is really low and I should have no problems, just want to be a little surer about it before I make the leap .
The flow chart is in this link .......... https://www.pentair.com/content/dam/extranet/product-related/product-brochures/pool-and-spa-equipment/SuperFlo_VS_Variable_Speed_Pump_Brouchure_English.pdf
Thanks for any guidance !
